potrzebny pinout liczników
jak w temacie...
chce do siebie wlozyc Rs4 zegary i nie pasuje jedna wtyczka
skalarx
Re: potrzebny pinout liczników
Post autor: skalarx »
aw69 pisze:jak w temacie...
z A4 pełny FIS więc powinno pasować:
Blue 32-pin multi-pin
connector
for basic functions:
1 - Terminal 15
2 - Brake pad wear
3 - Tachometer output 1
4 - not occupied
5 - Tank sensor
6 - Tank warning OBD 2
7 - Terminal 31 (sensor Ground (GND))
8 - Coolant temperature
9 - Terminal 31 (load Ground (GND))
10 - Oil pressure 2 (high)
11 - RPM signal
12 - A/C shut-off
13 - E-Gas/glow plug control
14 - Level control
15 - Terminal 58d
16 - Trailer turn signal
17 - High beam
18 - Left turn signal
19 - not occupied
20 - Terminal 58s
21 - Driver door contact
22 - Low coolant
23 - Terminal 30
24 - Terminal 31 (load Ground (GND))
25 - Consumption signal
26 - Right parking light
27 - Left parking light
28 - Tachometer input
29 - Brake
30 - S-contact
31 - Tachometer output 2
32 - ESP/ASR
Green 32-pin multi-pin
connector
for auxiliary functions:
1 - Door contact (all doors)
2 - Transponder 1
3 - not occupied
4 - not occupied
5 - W-wire
6 - Tailgate
7 - Right turn signal
8 - External buzzer
9 - External gong
10 - Airbag
11 - Stand-still time output
12 - Terminal 61
13 - Parking brake/BRAKE
14 - CHECK
15 - Oil level/oil temperature
16 - not occupied
17 - Transponder 2
18 - CAN high speed (powertrain) (high +)
19 - CAN high speed (powertrain) (low -)
20 - CAN high speed (powertrain) (screen)
21 - ABS
22 - CAN low speed (comfort) (high +)
23 - CAN low speed (comfort) (low -)
24 - CAN low speed (comfort) (screen)
25 - Engine lid
26 - not occupied
27 - Belt buckle
28 - K-wire
29 - Outside temperature -input
30 - not occupied
31 - Selector range display
32 - not occupied
Gray 32-pin multi-pin
connector
for multi-function display
1 - Menu selection switch (menu)
2 - Menu selection switch (out A)
3 - Menu selection switch (out B)
4 - Menu selection switch (Enter)
5 - CAN high speed display (high +)
6 - CAN high speed display (low -)
7 - CAN high speed display (screen)
8 - Passenger door contact
9 - Right rear door contact
10 - Left rear door contact
11 - Enable
12 - Clock
13 - Data
14 - Brake light
15 - Windshield washer fluid level
16 - Rear lights/low beams
17 - Left board computer
18 - Right board computer
19 - Board computer, reset
20 - not occupied
21 - not occupied
22 - not occupied
23 - Button branch 1 navigation
24 - Button branch 2 navigation
25 - Button branch Telematic
26 - not occupied
27 - not occupied
28 - not occupied
29 - not occupied
30 - not occupied
31 - not occupied
32 - not occupied
no dobra ale ja mam zegar z S4 z duzym fisem i dwie koski pasują niebieska i zielona....środkowa tylko nie pasuje jest inna niżw Rs4.... co wtedy ?
przecież mówiłem Ci że wyślę jutro 3 wtyczki
wtyczki wtyczkami....ale trzeba wiedziec co i jak podłączyć. Do tego jest mi potrzebna pinologia obu liczników
sokol22
Post autor: sokol22 »
ty masz zapewne srodkowa czerwona a rs ma szara szeroka wejdz na a4 klub tam masz wysztkie rozpiski pinow co i jak z fisem, bez fisa, po lifcie i przed liftem :)
To ze tylko srodkowa Ci nie pasuje to nie znaczy ze boczne pasuja ;) wszystki bedziesz musial przerobic :) Miedzy zielona i niebieska sa kable pomieszane miedzy tymi licznikami.
skalarx
a jaka jest ta trzecia, nie pasująca wtyczka? kolor i ilość pinów.
[ Dodano: 2012-09-12, 10:56 ]
nosb pisze:To ze tylko srodkowa Ci nie pasuje to nie znaczy ze boczne pasuja ;) wszystki bedziesz musial przerobic :) Miedzy zielona i niebieska sa kable pomieszane miedzy tymi licznikami.
e chyba nie. zielona i niebieska są wszędzia takie same chyba. Kwestia tej szarej środkowej. W zegarach bez komputera pokładowego jest np szara 32 pin i zielona 32 pin i pasują idealnie do licznika z pełnym fisem jak w S/RS. Podpinasz i masz. Potem trzeba tylko uspokoić choinkę na fisie bo brakuje mu sygnałów do szarej wtyki.
całkiem mozliwe bo niemam komunikacji z szafą z RS'a jak podepne 2 pasujące kostki, natomiast z dwoma podpiętymi od S4 jest komunikacja.... moj ori zegar z s4 środkowa ma czerwoną kostkę
[ Dodano: 2012-09-12, 19:56 ]
no to wychodzi na to ze w S4 z początku produkcji 99 rok są jeszcze zegary przedliftowe z fisem tak ? Ma ktos rozpiske zegara przedliftowego z FISEM ?
krzzaj5
Post autor: krzzaj5 »
mam taka przejsciowke zrobiona przez kolesia ----- a4 b5 kosci 32/32/20 pin jak u ciebie pelny fis 98r....do zegara z rs4 32/32/32 piny jeszcze nie zamontowalem jej wiec moge ci porobic fotki
mam juz kompletne kostki z RS4 i pinout liczników przedliftowych z FIS i poliftowych z FSI....poradze juz sobie
